I'm okay with some restriction if it means significantly quieter. I'm considering 2.5" exhaust after the Y anyway which should help alleviate any restrictions anyway.
Is this for the TJ or the LJ, I haven't kept track of which you are building? Does the mid-arm effect the space for the muffler?
You wouldn't happen to know the dimensions of the body of that muffler would you?Hush Thrush in my TJ. It is nearly as quiet as stock. And it will fit your LJ far better than the mess I made on mine.
I ended up with the Thrush welded. It won't be nearly as quiet as I want, I'm sure. But it fits and I was in a jam.
As far as I can tell, the hush is a rolled/crimped style body with multiple passes with fiber matting (or something). The welded muffler is essentially just a welded can so it's got that going for it, but it has no matting, so the gases just pass through it like a maze.What's the difference between the welded and the hush?
A glass pack will more likely change the tone rather than volume. I’ve experimented with a few muffler combination and found that a glass pack in combination with the oem muffler yielded the same volume - but lower more rumbly tone than just muffler. I would add a glass pack if the tone or resonance isn’t what you want.The Thrush Hush arrived today and is going to fit perfectly between the belly skid and the mid-arm.
Is there any sense in adding a glasspack before the cat to further quiet things down?
Is 2 mufflers quieter?
Yes - it all comes down to surface area. Doubling mufflers or running larger ones are significantly quieter.
Depends on the muffler. Let’s say you were to put two oem mufflers behind a blown motor, that needs more airflow than the muffler can give without resistance the a change would be obvious. On a stock engine the change is performance would most likely be as significant as removing it would improve - little to none.does running 2 in series increase resistance and or constric the flow of the system?
