yep it was easier to adapt the larger body then a smaller oneGot it because its a larger scale model
I like that you modified a die-cast. It gives it some realistic weight that you wouldn’t normally see on a lex bodied R/C.yep it was easier to adapt the larger body then a smaller one
Get an xmaxx if you want indestructiblemy kids would love this for about 45 minutes until they broke it (we've broken 4 cheap RC cars in the last year). Still makes me want to build one and hide it until they're old enough.
Ya my goal is to get it a realistic as possibleI like that you modified a die-cast. It gives it some realistic weight that you wouldn’t normally see on a lex bodied R/C.
That body roll and bounce does it, now for some motor sounds and close-ups on some terrain and you could get away with calling it full size.
Actually, the Axial SCX24 that the op used as a base is pretty solid. Not cheap, 120 for the wrangler JL version, but everything is replaceable and/or upgradeablemy kids would love this for about 45 minutes until they broke it (we've broken 4 cheap RC cars in the last year). Still makes me want to build one and hide it until they're old enough.
Ya that was my issue so I decided to go with a even smaller version and it came out wellI've got a couple of Axial SCX10 IIs and have been searching for a 1/10th scale TJ or LJ body. Tamiya has a YJ, and it's styrene, so it could be modified. My concern is how tough it would be afterwards. Other than that, all I've found are toy bodies with very poor detail.
