Radiator install issue
Boomer453
Louisiana
2006 TJ X, 6 speed manual.
Replaced a cracked radiator with the Mopar replacement and after recounting the shroud onto the factory holes on the radiator the shroud sits about 1 inch, the fan blades make contact at the bottom of the shroud.
Anyone else ever had it happen? I'm off to buy a new shroud- this one got broke lol
I've only ever seen that happen when adding a body lift. Did someone maybe previously drill a second set of holes in the shroud, which you used by mistake?
Drilled a new set of holes in the shroud. But it is going to need replacement, it sustained some damage.
It never ends.
It's MUCH better to just move the fan shroud down 1-1.25" than cut the bottom of the shroud off which significantly reduces its ability to pull air through the radiator.
Now you tell me😜
I agree 100%.
Luckily my system stays a constant temp just shy of 210 mark since it was cut over a year ago.
