Radiator Replacement
jbrenden
Dallas, TX
Hey, all. So this is my first posting here and I'm trying sorta out a radiator placement (developing a crack in the top on mine near the upper hose inlet). I've got a 2002 4L with a 5-speed manual transmission. Maybe I'm missing something obvious here, but everywhere I look all I can seem to find is the radiators with the transmission cooling line ports (generally on the bottom rear of the radiator assembly).
Is this just a matter of capping those ports? I assume those transmission lines would be isolated internally from the water line through the core and thus wouldn't affect the other functions of the system? Or is that not an accurate assumption?
Anyone have a good source for parts? I've tried the usual suspects (Mopar, ExtremeTerrain, 4wheelparts, Jeps) and I keep finding the wrong radiators. Is there a key to getting past the automatic variants that I'm missing?
You're correct about the auto trans ports; they are isolated from the coolant. You can plug them or leave them as-is. The aftermarket makes one radiator to fit either auto or manual transmission applications.
Reactions: L J
For me…. Quirk Parts has been a great source for hard to find Mopar parts.
I have used them to find parts that were otherwise out of stock in other online sources.
I purchased a set of NOS door panels cheaper than used ones at other online sources.
Reactions: TheBoogieman
