Hey guys, looking for a little specific advice relating to some of the info in this thread. I'm currently running a 1.25 body lift and am going to be adding 1.75 coil spring spacers (budget boost to fit 33" tires for mainly street use). Im currently running stock shocks so planning to get longer ones to accommodate the extra BB height - i want to get the Rancho 5000x shocks and an trying to decide between the different length options. There's a set listed on Amazon for 0-2" lifts (Rancho site describes them as being for 0 lift) and the next size up are the ones linked to a couple of times in this thread which are described on Amazon as being for 2-3" lifts (the Rancho site says they're for 2.5 inch lift). I usually follow the manufacturer recommendations and would go with the 0-2" set for my 1.75 BB, but since they're both for a range, presumably the 0-2 is setup to be perfect for a 1 (the average) with leeway in either direction and that the 2-3 is setup to be perfect for a 2.5 (the average) with leeway in either direction, in which case if be inclined to get the 2-3" set since 1.75 is exactly 0.75 from the middle of both ranges and would give me a little extra cushion if i ever decide to increase the lift height at all. I may be overthinking this and would be fine with either but I'm a newb with a limited budget so I wanted to run it past you guys first before i make any expensive mistakes. Thanks in advance for your thoughts.
