Red Is a good color! Moab 2014!
I like that. I bet that looks pretty mean driving down the road.
Southport. I have seen that LJ. There are a few in town that I have seen. A real nice red TJ as well.Hey Rob, small world. What side of the tracks are you on? LJ your color just drove by my house last night.
So to provide more detail over the last year I built a new 06 LJ and as soon as I regeared I had vibration issues as well. I went back through and made sure that all the control arms were the same length, the axles were perpendicular to the frame and made sure track bars are within 16th of an inch on center at ride height and played with pinion angles many times. I pulled the front driveshaft and no change so I knew it was isolated to the rear. Lifted up vehicle from axles and checked run out of driveshaft. I also habe an Adams rear driveshaft and he also sent me out a replacement and while it was a little bit better still have vibration. Best angle I found was about a half a degree less than the driveshaft. Changing the transfer case mount helped as well even though the original one looked fine. Before it would come on about 50 miles an hour now it comes on about 65 miles an hour so heading in the right direction. Also have had the new wheels and new tires rebalanced twice and the last time they called it a load force balance that’s where they actually put a rolling drum on the top of the tire and counterbalance based on high spots as well. No change after the load force balance. I have an advance adapter SYE and a UCF skid plate/tummy tuck. The skid plate is not flat to the frame but still an inch and a half or so higher than stock. Ball joints are good and new Currie correctlink steering. Of course it’s a LJ with a longer drive shaft so I shouldn’t even have this problem as my 99 TJ with a 4” Lift can drive 80 without vibration. I have not looked at specific run out on the yolks as I’ve read earlier in this thread I’m really hoping it’s not the advanced adapter because then I would have took my transfer case apart a third time as the first time I installed it it leaked for some reason so I used an ungodly amount of RTV the second time. Actually I take that back I would be willing to take apart a 3rd time to get rid of this damn vibration any other thoughts on your vibration challenges? I would say mine is now livable but with all the money and time invested and the fact that I like to solve problems not live with them I’m still searching.
The one thing I didn’t mention it is at 55 to 65 I can shift from two high to four high back to two high and absolutely no change in vibration. Bob if you’re ever in town we should get together and drive each other‘s rigs perhaps two heads are better than one and we can help solve each other‘s problems but I would definitely do the tranny mount it’s pretty quick it’s half an hour job if you got a Jack, a block of wood for the tranny, 18mm and 13mm. It reduces the overall drone as well as the pulsating drone sound, now it’s more of a reduced steady vibration/sound that you spoke of earlier in one of your post.
Don't always think you can eliminate the front axle by simply disconnecting the front driveshaft. If either of the front u-joints or axle shafts inside the front axle are shot, bent, or worn out, they still spin and can cause cyclic vibrations at speed.
I'm pretty sure I buggered up the RH u-joint when I installed it. Prob dropped a needle bearing. Gonna tackle it this weekend and post the results. Been chasing that vibration for months!
IME, we never had an issue with vibs generated from a rear end that wasn't in bad shape, eg, blown pinion bearings causing the pinion gear to become loose. But that you would have found by now. If a gear set is set up significantly out of spec, you'd hear gear whine mostly under acceleration and/or steady driving. If you want, grab some gear marking compound, pull the cover, grease up 8-10 ring gear teeth, spin the wheels, take some pics, and post them up.
