Rear coil springs
Hooey
Northern CA
I have a 2004 TJ Rubicon with a 3.5" Rubicon express lift. I carry a good ammount of equiment in the back and it has caused a bit of a "sag" in the rear. My question is ; is there an option to raise the rear back to the normal height? (Perhaps 2"). Maybe heavy duty rear springs? I
Don't want to lift it any more than the original 3.5" lift, I just want to bring it back up to the normal height.
How old are the shocks in the rear?
You would need to start calculating/comparing spring rates of the various offerings in regards to coil springs to find one that will sit higher with weight on them.
Shocks are brand new Bilstein's
You could look at LJ specific Currie 4” springs or look at other 4-5” spring options to compensate for the weight.
What you call a normal height is your desired ride height. Measure how tall your current springs are as the Jeep sits in the driveway. How much more ride height do you want?
