https://en.wikipedia.org/wiki/ScaldingWhile you can touch 200 degrees, you can't touch it for more then a few seconds without discomfort. My hands are my temp gauge on my cookers to see if they're running too hot.
There not brand new I got from a Jeep guy that was selling themFull axle swap (housing and all)? New gears not broken in yet? How are the bearings?
I’ll have to get a temp gun the ebrake isn’t hangingAlso other thought, is the ebrake hanging up? That would drive good heat. Like @toximus said, if you use an IR gauge you can narrow into where in the axle is the hottest. That narrows it down pretty well.
Honestly I walked by the rim and felt a lot of heat soo I touched it and it was very hot so I went under and touch the dif cover was also very hot I thought the ebrake s where hanging but there notYour axle wouldn't be getting that hot as you're describing without something noticeably wrong....as in audible growling/groaning...e-brake hanging up which will result in lack of drifting fore and aft...
I'm curious about something...
Most people without any other signs don't think....
"hello self...jeep is running good...I think I will have a feel around my rear axle just for fun today."
How and or what made you go get all touchy feely with the rear axle to begin w
Hey bud I said in my post what was the problem I also told you everything please move on if you got nothing nice to say thank you.Well said...I think I misunderstood the thread title....I thought it said need help. But I think it meant I’ve got a problem but I want to argue with any advice that you guys gave me and not tell you everything.
It does not have a aftermarket dif cover I have a stock one it’s filled to the fill hole I believe I put in 80-90 or something like that I’ll have to see the bottle when I get homeMy gears are properly set up and I’m a state away weather/temp wise and as Jerry said, the diff will get fairly hot after a trip on the highway. Without exact temps we can only guess what’s normal and wants not. Starting with the easiest first- you say the diff fluid is full - what’s full? Full as in I added 2 qts but have a massive aftermarket diff cover so it’s below the axle tubes? Or full like I added until it blew out the breather? Also what oil? The type can also make a difference but I doubt to the degree you’re experiencing.
That viscosity is fine, no worries there. Until you give us actual temps of the axle at different locations with an IR gun we're all guessing. But again, the normal temps of an axle after it has been driven will be hot enough that you can't hold your hand on it for more than a second or two before it'll be too hot to continue doing that. 140-175 is considered in the normal range after it has been driven for a while.It does not have a aftermarket dif cover I have a stock one it’s filled to the fill hole I believe I put in 80-90 or something like that I’ll have to see the bottle when I get home
We kept saying - get an infra red thermometer. We believe you its hot , how hot is it. Trying to help you get a reference point. And as Rubi said, if you are feeling around your rear diff, it seems you might know something is going on with it ....as in checking the work, etc.Hey bud I said in my post what was the problem I also told you everything please move on if you got nothing nice to say thank you.
You've told us everything except anything important. What are the actual temps? How hot did the rear end you removed or the previous gear set get after an extended run at highway speeds?Hey bud I said in my post what was the problem I also told you everything please move on if you got nothing nice to say thank you.
You're just fucking with him because your brother in law sells temp guns.We kept saying - get an infra red thermometer. We believe you its hot , how hot is it. Trying to help you get a reference point.
He owns TempGuns R Us, and i’m going to have to support him if it doesn’t work out. He already went broke drilling for cork.You're just fucking with him because your brother in law sells temp guns.
Well, the good news he doesn't sell Stud Finders since he'd go broke in your part of the world.He owns TempGuns R Us, and i’m going to have to support him if it doesn’t work out. He already went broke drilling for cork.
You need a flashlight.Very insightful....I can’t even find my rear end with both hands.
Thanks for information regarding "Scalding" from hot "Fluids" but that's not the case here or when I check my cooker temps or touch anything hot there is some amount of air between my hand and the surface area I'm checking and the skin contact surface is much less then submerging in a fluid. Just sayin!
