I apologize for a second threadsurrection on this forum in two days. It was suggested that I seek help in this thread.
I have read this thread, but I am still not certain what to do. And after looking at my initial theory of what to do, now I think that theory is incorrect and I wish to proceed with due caution.
1998 Jeep Sahara, 4.0, manual, with what I theorize is an aftermarket rear towing hitch attachment.
Where I am at:
I purchased some recovery hooks, Rugged Ridge 11236.02 and they differ from what I see in the above pics. Three holes instead of two. So that may be my first error. I numbered the holes in the pic below.
Secondly my towing hitch attachment is different than the other examples and appears to use a higher and more rearward bolt hole with a bolt the goes through both sides of the frame.
What to do?
Theory A:
Use the FRONT bolt hole for the tow attachment and go through hole ONE on my hook. Use the bolt that came with the Rugged Ridge hook and bolt it inside the frame fiddling the nut in as previously described. Discard the bolt from the tow hitch.
Drill a new hole at approximately the location of hole THREE in my hook. Go through the tow attachment plate and one side of the frame. Fish nut from Rugged Ridge kit inside and bolt using the RR bolt.
Ta Da!
Theory B:
Use the FRONT bolt hole ...(same as Theory A)
Drill new hole using hole TWO in my hook. Allowing a steeper angle and a longer throw lower down for rope clearance.
Ta Da! (Until the hook breaks because hole 3 is unsupported? Ta Doh.)
Thought and help appreciated. Two Pics follow.
