Hi Guys,
I just bought new axles and an OME 2" lift. I just removed the back axle and my spring tower is hanging on by a thread. The frame itself is ok, but I would like to replace the spring towers (is that what they are called?). I did some research but wanted to get your advice.
Here is a pic:
https://goo.gl/photos/mxbZL7viNwahZEwv6
I was thinking it would be a great opportunity to chip the old frame mount off and reposition them so the spring sit straight up and down. I found someone that did it w/ the same make and model as mine:
http://www.jeepforum.com/forum/f9/rear-spring-tower-rusted-away-1997-wrangler-1192291/
and they pointed to this particular product:
http://www.ballisticfabrication.com/Coil-spring-Frame-mounts-with-retainers_p_1478.html
My question to put out to everyone is to ask if anyone else has done this and what mount did they use? Also if you ran into any problems etc.
Thank you!
Here is a pic:
Thank you!
