No problems with mine, nor do I expect any.
The failure/fuse theory is based upon the belief that the 5.38 pinion is too small and/or has too few teeth. However, a side-by-side comparison of Revolution's 4.88, 5.13 and 5.38 pinion gears for the Jeep TJ Dana 44 shows that not to be the case.
There is a photo that has been posted in several threads on one or more jeep forums, which I think I re-posted someplace as well.
Edit: I found the thread. I'm so embarrassed because I'm the guy who started it and it is a classic example of analysis paralysis and making an easy project difficult. It also marked the occasion of my very first telephone conversation with
@mrblaine and my first experience with his version of the Socratic Method, which is to not waste time asking questions until you discover for yourself that your idea is foolish, but to tell you right up front that your idea is completely full of shit and then ask questions until your newfound knowledge becomes understanding. Unless you are not a receptive audience. In that case the call is pretty much over.
Fortunately my skin is almost as thick as Blaine's and so far almost has been almost good enough.
Here is the thread on Jeep*****.com:
https://www.*********.com/forum/f9/questions-re-jantz-engineering-jana-k4-kit-jk-gears-lj-rubicon-dana-44-axles-4201610/index2.html
[Replace ********* with jeepforum]
From that thread:
Revolution first released the 5.38 Rubicon "thick" gear sets on 10/29/15, so they have been on the market for awhile.
Tooth Count:
4.88 - 8 pinion, 39 ring gear
5.13 - 8 pinion, 41 ring gear
5.38 - 8 pinion, 43 ring gear
Photo of 5.38 pinion on left, 4.88 pinion on right
I doubt you will find any first hand reports of failures that can be proven to be in any way related to 5.38 gears acting as a fuse or because the pinion head was too small or had too few teeth.
