Awesome marketing.What made you decide on drilled and slotted?
Better Braking...What made you decide on drilled and slotted?
Maybe... if you're racing.Better Braking...
If only that were true, it isn't.Better Braking...
Don't let these old timers push you around..you and I both know slotted rotors are better..Those are only your opinions... I believe they are better and have never had any issues with them in any car I've put them on.
This is only the third Jeep I've used them and installed them on dozens of cars. In my opinion, they simple work better.
I still see them used on many performance cars out there also and until I find and see proof otherwise, I will continue to recommend them.
I'm old too tho... LoLDon't let these old timers push you around..you and I both know slotted rotors are better..
You probably won't have "issues". They just don't do anything for a TJ.Those are only your opinions... I believe they are better and have never had any issues with them in any car I've put them on.
Do you autocross your TJ?I still see them used on many performance cars out there also and until I find and see proof otherwise,
It's your money to spend how you wish but we will continue to not recommend them.I will continue to recommend them.
They are proven to work better.You probably won't have "issues". They just don't do anything for a TJ.
where it relates to TJs...They are proven to work better.
They also work better in wet conditions.
They don't cost that much more.
The picture says like 1000 encyclopedia’s!I would never try to tell you which brakes/rotors work best with larger tires on a TJ, so I won't say a thing.....................
MR BLAINE is our resident forum brake expert and that is not an opinion; it's a fact....Those are only your opinions...
Hey, the OP has all of 34 posts and has earned the right to call out Mr. Blain and Jerry Bransford, what the hell do they know about these TJ's!Those are only your opinions
They weren't even half worn...Those inside rear pads must have been toast! You're gonna get flack for the rotors, I wouldn't sweat it, the sky isn't going to fall
