Found a lot of play at my steering ujoint. Summit has a replacement:
https://www.summitracing.com/parts/...laming-river&gclid=CMyCxK6J8c8CFUxsfgodx9cMEQ
Though to use the summit ujoint, you'd have to cut the ears off the lower steering shaft to get this new joint to work (which shortens the steering shaft). How much force does this part of the steering see? Would cutting the ears off and welding on a small extension be too risky?
