OK, so I ripped out the exhaust (and intake) manifold and put back in with a new felpro gasket to see if an exhaust leak was the cause of the nasty ticking noise in my new-to-me 2001 4.0L. Nope, not the prob. It's a main bearing or lifter rod or collapsed lifter, or gremlin poo (or, whatever). Ah, no horrible surprise, it has 190K miles...but a bummer just the same.
So now imma swappin' out the motor for a 2004 salvage yard unit with 88K miles (thar's an improvement) and a 1 year unlimited mile parts & labor warranty (for free, no less).
Here's what I'm deff doin':
* replacing the rear main seal. Yepper, no brainer there.
* replacing the valve cover gasket (can't put the "new" engine in without taking that off and giving it a good look see anyway).
* Oil, oil filter, and coolant will all be replaced and I'll be moving the brand new (and tested) thermostat over as well.
Also...
* Serpentine belt is good.
* Spark plugs in original engine are nearly new E3's, so they'll go.
* My radiator is recent and in very good condition.
* Both exhaust manifolds are pristine. Since the originals had some obvious signs of previous leakage, I got some awesome replacements (too bad they were not the problem).
What other thangs would you guyz n' galz suggest I do while I have the front part of the Jeep all torn off and the donor engine in-hand?
Also...
