All, I have spent the better part of the day trying to replace the Steering Dampener. Its only 2 bolts and the Jeep has no rust, this should have been easy.
For the life of me, I cannot get the bolt out of the Drag Link. I have tried multiple methods, including the one that @Jerry has recommended for years of hitting the drag link to the side of the bolt with a 3lb sledge. Yes, I put real muscle into it. . It didn't pop out. I think it actually laughed at me.
I also threaded the castle nut on and tried to hit it with the 3lb sledge. I only succeeded in removing the threads from the castle nut.
I have soaked it down with PB blaster and used my Ball Joint remover and Pitman Arm Puller. Ball joint remover did nothing. Even got the breaker bar on the Pitman Arm Puller and that only resulting in breaking one of the ears off of it. So I guess I no longer have that tool.
I feel like drilling the thing out will only make a mess of it as it is a tapered bolt. I don't want to be left with a "sleeve" that wont come out.
Any other thoughts as to how to get this thing separated?
