Don't tell her, then ask for forgiveness later.
I'm still in limbo waiting for her forgiveness for taking her bottle of rubbing alcohol to clean my floors before installing my BedRug. Apparently its hard to get these days.
I was going to suggest this myself. I have used one many times when I’m in a bind. I believe the last time I used it was on the same issue op is having. I had swung once with the hammer and smashed my fingernail pretty bad on something mid swing somehow, used the air hammer & first pop and it was off.If you have an air compressor to use these things really come in handy. They’ll piss off the neighbors, but an air hammer with a flat bit does wonders for getting stubborn suspension bolts apart. I recently finished the front end of my TJ and did t have to swing a hammer once.
No need for a torch. Use a BFH (BIG fucking hammer) to bang on the SIDE of the drag link next to where the stud passes through it. Do not bang on the end of the stud which will just mushroom the stud and make it even harder to remove.
Damn, that was one stubborn bolt.
Wouldnt turning the steering left or right a bit help.... or taking preasure off the tires?
The Stabilizer is disconnected at the other end so there is no pressure on it at all. Just the bolt, stuck in the bar.
So I tried the air hammer. No go.
Finally decided to drill it out. Got it down to about 1/16" material left around the edges (even followed the taper) and still couldn't get it to free up. I have never had a bolt give me so much trouble.
But the problem is now solved. Got on RockAuto and ordered all the Moog parts to do the ZJ tie rod upgrade with new TJ drag link. Figured since I would need to align it, might as well get the Moog front upper and lower control arms as well. And since I got the front, went ahead and got the rear upper and lower ones as well.
So... Steering Stabilizer problem is solved. For a mere $467. Stupid bolt.
That's always how it goes, especially up here in the north.
At least it's done, plus you got a nice upgrade out of your frustration.
Putting a load on it with the puller and a smack on the side with the BFH . . . . . usually works.
I had this same problem, and worked on it for 3 days. I was told a few little taps on the bar near the bolt would be enough, and that they should be soft taps-no "King Kong" beating required. Didn't work. Tried torches. Didn't work. Tried two different pullers-neither worked, and both ended up bent beyond being of any future use.
I am a very patient man. Finally, on the 3rd day, I lost all semblance of patience. Got the 3lb sledge hammer (the 12 pounder's handle was too long) and started just wailing on the bar next to the bolt-I was not holding back at all and went full "King Kong" on it. I was prepared to absolutely destroy that bar, and that was my plan. If I needed to replace anything, well no problem. On about the 4th hit the stupid thing just went "sproing" and popped right out, like it was just waiting for me to do it this way: "Hi! What took you so long?" Just like Jerry Bransford said in his post.
I admit, I beat that damned thing down to about 1/4" in thickness until I could calm TF down. I had a full-on tantrum on that stabilizer like I was a two year old. Haven't lost my temper like that in decades. I kind of wish the whole thing had been caught on video-it would have been interesting and possibly humorous to see a supposedly grown man being owned by a farging steering stabilizer.
I couldn't agree more!I married the right girl.
