Reverse lights not working after LED tail light swap
IPerkWVU
Charlotte, NC
Reverse lights aren’t Illuminating after I swapped out the tail lights with LEDs.
Swapped out the reverse light switch at the transmission
fuse 7 in the glovebox looks good
Any special wiring need done with LED tails? I used generic trailer lights..
many suggestions?
Double check your grounds. Run a wire/alligator clip from inside the light to body ground. What happens?
False alarm, the new switch fixed my problem. I wasn’t testing it with the key in the ignition (just turning the switch previously).
thanks for the input though!
