Who out there knows if you can move your axles up and back just by turning the sleeve on double adjustable arms while on full load and not have to take anything else off to do it
Just wanted to. Move the axle back a hair to center them more under the bump stops
I’m just looking to extend them a 1/4 inch…..can that hurt anything?
Anyone got the torque specs on rockjock double adjustable LCA’S
I’m lurking here to learn; I hope to be setting up my new fully adjustable control arms soon. Good intel … since I’m doing springs, shocks and sway bar end links at the same time as the CAs I’ll cycle the suspension without springs to align bump stops at full compression by adjusting CAs, then tighten everything up if it looks good at ride height. Right?
You guys use anti-seize on the adjusting threads of the CAs and red Loctite on the fastening nuts that attach the CAs to the frame/axle, right?
Did they come out with a torque crescent wrench For jam nuts?
