Ok, assume this is the setup for both cases:
4” Lift, 1.25” Body Lift, 35’s and shocks designed to allow for the maximum travel with each fender setup below
Regular or Tube Fenders should maintain the factory 3.5-4” up travel
Under the assumption HL fender will give an additional 2-3” of up travel, is that what one would a good return on investment for all the modifications and work required to install. Would you consider it usable flex or is the 4” from factory enough for 99% of the type of wheeling out there? Am I overlooking something? Buy once, cry once and what to make sure the work I do is worth it. Genright Alum fronts are the same $ for regular and HL style. As much as I’ve grown to love this jeep, I don’t think I’d plan to go beyond 35s anymore because I enjoy driving it too and would rather build something else for 40s on down the line.
