I’m currently running a Rubicon Express front track bar with a drilled frame side mount. I’m starting to get a clunk and wandering from the front end and I believe it’s the track bar bushings. All control arms are tight(Currie/Savvy). Should I try to rebuild the RE track bar(they have bushing kits for $10) and try to buy a replacement heim for the frame side? Or buy a matching JKS bar like my rear has? My main concern is what to do with the drilled out frame side mount. Will I still be able to use a regular bolt or should I use a tapered sleeve if I go with a JKS bar.
