It’s balanced near perfect now. I had to lighten the rear about 100lbs plus the whatever the hardtop to soft top swap netted. I get 50/50 on the front and 45/55 on the rear. The travel is a about 10.25 front and 11 back. The front anti rock changed the “real travel” some. If you want to call it that. Last four trips the front rubber puck on the shock never touched the bottom on either side. Probably 1.5” from bottom. It works great so I’m not going to adjust the anti rock.How much F/R up/down travel do you have? I will have the 11" front / 12" rear setup once shocks are in and MrBlaine can fit me into his very busy schedule.
Chris's LSC reservoir shocks rode absolutely amazing (truly awesome) when he took me for a spin, so I'm going a similar route (but with DSC adjusters).
I should add that if you do high speed, the DSC’s are probably a good choice. If it’s all low speed, the LSC’s will do the job. My TJ is a trailer queen that tops out at about 60 so I’m all low speed.
