If you have expensive power, if your utility allows net metering, and your local subsidies are generous then your installation might have a reasonable payback. Payback is simple math with the total installed cost, the estimated system power generated on an annual basis, and your cost per kWh of electricity. Installers will try to conceal the actual total cost and will overestimate annual power generation to make it look like a great deal.
