I have been trying to get rid of this drift left in my Jeep for some time and have adjusted toe-in several times and have had it on an alignment rack a few times.
Currently my toe-in is at .20 total degrees, which is perfect, however, the right is at .20 and the left is at 0. So I need to get the right toed out and the left toed in. BTW Caster, Camber and Thrust Angles are all good.
Here's my theory ... when I installed the new steering the drag link it was installed to short. A short drag link would pull the toe in on the right when the steering wheel is centered. SO, if I were to lock the steering wheel at center and adjust the drag link adjusting sleeve to extend the drag link that would push the toe out on the right side where I could get it to .1 degrees. Then, with the steering wheel still locked at center I can adjust the adjusting sleeve on the right wheel to bring the left to .1 degrees for a total of .2 degrees with .1 degrees on each side.
Where am I wrong here or can someone tell me why all my toe-in is on one side?
