Shocks and coils compatibility
roger_caldas
Jeepers,
will a 3" procomp shock/coil set from a 97 Cherokee Sport fit a 97 TJ plug and play?
The front will fit, but obviously the rear won't work at all since the XJ rear uses leaf springs.
Are sure all XJs wear leaf springs?
Here's a pic of the set and it was installed in a XJ before...
I am 110% sure that all XJs are leaf springs. If you found an XJ with rear cool springs, then that was a completely custom fabricated rear suspension setup.
Reactions: mouth
All Jeep Cherokee XJ models come with coil springs up front and leaf springs in the rear. However, the grand cherokee model has coil springs front and rear. Perhaps that kit was from a grand cherokee?
Also beware that the XJ coils won't net the same amount of lift on a TJ and vise versa.
I'd avoid that kit either way. Pro Comp stuff ain't that great.
