Is it necessary to loosen and retorque control arms after doing a lift? How many members did or did not follow this procedure and what was the result?
This is more of a question for smaller lifts with stock style fixed length with rubber bushings. As the larger lifts usually have adjustable control arms that are reset during the process anyways. The idea is it reduces wear on the bushings?
Here is some info related to my particular situation:
I have a slight pull to right after doing a 3.5 inch front lift and 2.25 rear, toe in is already set to 1/8th inch, control arms are stock. Jeep was pulling to one side before lift also, but the Jeep had a 2 and 2.25 inch lift and was setup poorly. Could this be the result of control arms not being retorqued?
I wanted to do a poll but I guess that's not an option anymore.
