I have a 2003 jeep TJ 5 speed manual transmission and need to replace my clutch. After doing some research, I found a comment someone had made stating it is a good idea to change the CPS while you’re working on it. I have about 195k miles on my odometer and haven’t had any issues with the CPS. The reason I’m asking is because it’s price on rock auto is like $90. I can fork it over if it is needed but if I can salvage my old one, I’d rather save the cash.
Also is there anything other than that, the pilot bearing, throw out bearing, clutch, pressure plate, or flywheel that I should attempt to replace while it is cracked open?
