Well waiting on parts to finish my new ac compressor and accumulator install. Evaporator is good and does not leak. So should I replace the condenser? If so which brand? Don't want to burn up my new compressor.
You need to replace condenser and liquid line which contains orifice tube and runs from condenser to accumulator. You also need to check fan clutch !!!!!! Being a 98 wrangler all these parts need to be replaced ,
Do yourself a favor. Replace everything between the grill and firewall. If you need help with the correct parts, give these folks a call. I've installed two of their kits and used their parts to "refresh two other systems. Customer service is top notch!
Thanks for the advice. New condenser ordered. Will flush evap and hard lines. Going to replace orfice tube, compressor, accumulator, both pressure switches and hopefully I will have my ac back.
