I have Hayden 2791 waiting for me to install it. It will go with Derale 6 blade fan instead of OEM 5 blade.
I might be late to the party, but I replaced the fan clutch on my Tundra back in the winter. The clutch I removed was a USMW and it had “MADE IN USA” stamped on it, which gave a bit of confidence. It got stuck on full lock which is why I knew it needed replacing. Before that, it was very quiet even in the summer and followed the same characteristics as the Mopar one on my Jeep; loud at first but very quick to unlock once moving. I see no performance difference between this one and the OEM clutch that replaced it. This came off of a 4.7L V8.
When the Mopar unit on my Jeep goes out, I’ll probably give USMW a go. Seems that the consensus is Hayden does the job but generates too much noise; something that us barn-on-wheels owners aren’t too fond of.
Was it decently old when you removed it? I’m not scared of it going bad eventually, as long as it’s a reasonable service life. That’s good that it worked appropriately up until the failure.
My main complaint about Hayden is how dang loud it is. Almost feels like there is no fan clutch and like the fan is bolted straight to the water pump.
If you want a quiet car, buy an electric...
Fan noise doesn't concern me.
It doesn't "concern" me, but I don't need it to be overly aggressive either. When the aftermarket is significantly louder than the factory one, that to me tells me it's too loud, and that doesn't really provide any benefit.
Other than keeping the engine cooler. I want every erg of cooling power I can get - this thing has never run this cool since I've had it.
Well if you want that, go ahead and bolt up a solid fan with no clutch. More cooling power. There is a point where more fan doesn’t equal better.
You might have a different problem to address than additional fan clutch air movement.
It's not keeping the engine cooler by running when it's not needed, such as when it's not even hot enough to open the thermostat.
This is primarily for the newer Jeeps with a spin on clutch like my 2004 and the short answer is no, you should get what is called a severe duty clutch, the Mopar replacement or Hayden part number 2791.
@Longwhitejeep posted a few pictures that show pretty well what this is about.
A few years back I did a cooling system overhaul and purchased a Hayden 2771 heavy duty fan clutch. It is the Hayden clutch most part guides recommend for the 2004 wrangler. They cost about $40 now compared to the Mopar clutch which comes in at just over $120. I figured at the time heavy duty was great and it worked fine.
This time around I figured I'd research again and see if standard duty was available or what the best option was. Turns out Hayden shows each clutch design in their application guide:
Here is the Mopar fan clutch for the 2004 Jeep part number 68064765AA:
it appears the Hayden extreme duty fan clutch part number 2791 is very similar to what was installed from the factory and the guides list the wrong part. I'll leave it to everybody else to guess why they list the heavy duty and not the severe duty clutch, I don't really know. The severe costs about two dollars more than the heavy duty Hayden and about $90 less than the Mopar clutch. I think the Hayden heavy duty and severe duty designs in general are sold by several companies for our Jeeps, for example Murry and Four Seasons looks like they make a heavy duty style and other aftermarket clutches are the severe duty design.
If you read the details above in the Hayden application guide the extreme duty engages slightly less when idle and slightly more when active and is supposed to last a lot longer. I did notice when I installed the clutch it makes less noise than the heavy duty clutch did when the engine is cold and you can hear it engage a little sharper when things get hot but that's very subtle. It makes less noise on the highway as well. I haven't put many miles on it but I'll report back if there is anything to report.
There is nothing wrong with the 2771 or heavy duty clutch. I don't think anybody needs to swap one because of this. It worked fine for me, I just think it's the wrong part if you are shopping for a Hayden replacement.
Will this work on a 06 jeep wrangler rubicon 4.0?
I don’t think my Mopar fan clutch is operating correctly, but I wanted to ask in case I’m wrong.
Here’s a video of it, imo, not properly disengaged after sitting all night (current temp is 43*).
https://vimeo.com/915562573?share=copy
I bought the part three years ago to replace PO’s failed electric fan. This part may be why my gas mileage has dropped…it seemed too extreme to only be a winter fuel issue (if that’s even a thing in Tucson)
I may get this clutch if your are still having good luck with it @freedom_in_4low
hard to tell how much force you're using to spin it, but mine does not freewheel after I spin it, either (it's sat overnight and the outdoor temperature is 48°F) so I'm not sure you can condemn it based on that.
Between the USMW and two Hayden's (including one that LOOKS just like the Mopar), they all even make audible fan noise when I first start. The difference however, is that the Hayden would ROAR the entire 5/8 mile out of my neighborhood and onto the main road, whereas the USMW quiets down before I hit the end of my 90' driveway.
When I got sick of the Hayden was when I was wheeling at high elevation in Colorado, with temps in the 40-50s, basically engine braking down an easy 3,000' descent for 2 hours, so basically zero engine load. My thermostat had malfunctioned and ECT wasn't even getting to 170 - I could barely hear my GMRS radio over the fan noise. It should not have been engaged at all according to factory specs which call for engagement when air coming off the radiator exceeds 170°F. The USMW seems to behave correctly this way - past the end of my driveway, I don't hear it unless the engine is actually up to temp and I've been at a stop light and the weather is well into the 80s.
