While I was flushing fluids on my newly acquired SE, I decided to remove the remote P/S reservoir to give it a good cleaning. I had already taken the shroud off to change the radiator so it was just dangling there. What I found is a fine metal screen on the return side. Looks to be a little larger than a quarter. At first, I didn't even see the screen thanks to the build-up of sludge coating it. After detaching it from the rubber lines, I shook and drained the reservoir a few times with solvent. I then sprayed brake-kleen with the red nozzle extension from the port side and through the fill opening. Blew it out with air and there was a nice clean shiny metal screen.
I can't imagine how the power steering was even functioning. I would probably want to clean this every few years. Likely this will extend the service life of the pump by many years.
