The 2001 TJ was driving fine on Saturday for lunch, but wouldn't start a few hours later. Turned the key and dash lit up, but heard a snap when I tried to start it, and then everything went out (see video). It's repeatable: if I wait over a half hour it will light up again and snap.
Edit: video loop
- Voltmeter shows 12v on the battery (this is a 2 month old battery, too).
- Checked all the fuses. I replaced #2 and #7 anyhow because I couldn't tell whether they were bad through the worn plastic.
- The dash lights and the hood lamp are bright before cranking. Radio works.
- Key in accessory and in run light up everything fine--until cranking.
- My ohmmeter is toast and I'll have to buy another to check resistance on relays.
Edit: video loop
