As a couple of you guys know the previous owner was so kind as to leave some sheared off bolts in my donor dana 44. I drilled all holes out to the appropriate size to accept the 1310 ubolt and curious if anyone has a clue how much I should torque the nut and if I should use loctite (Just as the factory had the straps secured). Would hate to under or overshoot it. Thank you!
