I have noticed a few ' Is my PCM bad' threads lately.
A few observations I have made over the years of dealing with Chrysler PCMs and their wiring-
- PCMs fail rarely ..but they can.
- look into sensors first. If possible swap with a known good sensor. New bad ones happen and can send you down the wrong path.
- get the wiring diagram for your year jeep. This is important. You cannot properly diagnose shit without the wiring diagram.
- buy a ohm meter. Cheap ones usually are ok.
- check the wiring. Chrysler sucks at routing their wiring. Look for rub marks on the looms. If the loom has been rubbing on something for a while, the wiring inside could be damage. Use a meter to check from pin to pin on the connectors. ITS ALL IN THE FSM WIRING DIAGRAMS!
-When all else fails, start looking into PCMs. It could be bad, but assume something else is first.
Good luck. Wiring can be a pain in the ass, but if you want to play with 20 year old vehicles and not pay someone every time there is a problem, you need to how to deal with it.
