Space it back just enough to get a nice space to get a bead in the “corner” between the two pieces and enough that it allows you to get a bead to the tube as well. The entire bottom doesn’t need to be welded to the tube side to side. More is probably better though…
As long as you don’t push it back so far that you intrude into the opening of the holes for the bushing you will be ok…
