Long story short is it safe to drive the TJ with the speedometer not working from a mechanical perspective? (I need to drive the jeep then next few days and don’t have time to dig into this further until Thursday evening). I can use gps for actual speed.
Speedo is not working after I pulled the Speedo sensor from the transfer case to see what tooth gear was in there. I put it back several different times and tried to slightly adjust the orientation so it would catch and no luck. I also make sure connections are clean and secure.
Sent from my iPhone using Tapatalk Pro
