Speedometer doesn't work
Igoo65
Colorado Springs, CO
I have a JB Conversions super short SYE and I was driving down the highway and my speedo went dead. Has anyone had this problem? I checked my connections and everything seems to be ok. Is there a fuse somewhere for the speedometer?
Igoo65
Have you pulled the speedo gear to take a look at it?
My speedometer is not working either I need Info about the fuses I think it might be one of them but am not sure where... cause I was installing the radio and my dumb ass put the positive cable with some other cable and it pop 😅 now I think I mess up one of the fuses but not sure witch one... any help please??
Sorry, I forgot to post what happened. I called JB Conversions and found out I had a bad pickup. They sent me a new one and it has been running good ever since. I can't remember if there is a specific fuse for your speedo. What you may do is pull each fuse and check to see if you have a blown one. There is a fuse panel behind the glove box and the power control unit in the engine bay next to the battery. Good luck.
Reactions: Jmag
