Hello, I have a 2003 tj, manual 4.0 L
It went through a full body off restoration. I have been working through the hiccups associated with that type of project.
It's finally gotten to the point that it's ready to enjoy. The last time I picked it up from my mechanic everything was going great for about 45 minutes then it just quit !
All the dash lights worked, it would turn over, my mechanic confirmed it was getting gas, but would not fire. After a rest period, about 10-15 minutes it cranked up.
It ran for about 10 minutes and died again. After a longer rest, probably 30 minutes it again started and we were able to drive it the 10 miles back to the shop. I had this problem previously, and replaced the ECM and thought it fixed it because the ECM gets so hot you can't touch it when this happens.
I called Mark @Wranglerfix to see if he could help me. After discussing the situation we don't think the problem can be the ECM as it did the same thing with both of them.........................
My mechanic said it could be the TIPM, however Mark told me that this year doesn't have one.
I don't believe we are getting any codes except the one pertaining to the unconnected evap canister in the passenger rear fender well that was broken during the replacement of the fuel pump and no one has figured out how to repair/replace it.
Any suggestions/ideas would be greatly appreciated.
First time on a forum, not really sure how it works.
