Hi all, new here. I've got a 99 4.0 Auto 3 Speed that's been acting up on me for the past 2 months. While I'm driving, under any load condition (A/C, heater, headlights, etc on or off) it wants to cut power or fuel to the engine. I have to "save" it by slamming on the gas to prevent a stall, and it does fully stall out if no gas is given. Speed and tach drop, but I can't tell if it's electrical or just result of speed/rpm loss due to no gas. All other electrical systems remain working, and I get no CEL or codes. Only time I get a CEL is when it loses throttle intermittently. CEL shuts off immediately after normal throttle returns to the engine. It is worse after longer operating times/higher temperatures, but at lower temps I can trigger it by driving over heavier bumps or potholes, of which we have many. (ODOT...)
I've thrown $200 in parts and a shop visit at this, and the shop said they couldn't induce a stall or reproduce any issues when they drove it.
Things I've tried from reading forum posts:
Replaced Crankshaft Position Sensor (Walker)
Cleaned Throttle Body
Throttle Position Sensor (NAPA Echlin)
Upstream O2 Sensor (NAPA Echlin)
Vacuum system was checked by the shop, including the MAP sensor, no issues or leaks found
Alternator/belts are less than a year old
Air Charge Temp Sensor (NAPA Echlin)
Checked, cleaned, and reset all system grounds
Cleaned battery terminals and fully recharged battery
Pulling, shaking, and otherwise jiggling any wire I could get my hands on in the engine while running to listen for any drops or idle roughness, found nothing.
Things I'm suspecting/Leaning towards:
Fuel pump assembly, wiring or similar. Gas gauge was acting funny earlier this month, I would watch it surf from F to E then settle at 1/2 or 3/4 only about 2 miles away from a full refill, but I haven't seen that happen for a week. Fixes itself when power cycled.
Camshaft position sensor under the distributor, though I've seen that this would normally cause a code and inability to start, neither of which I have had.
Please, if you have any advice, let me know. This is driving me crazy because it's still driveable but lurches worse than a rodeo bull when accelerating both when straight and through turns if my touch on the gas isn't lighter than a feather.
