Steering cooler mounts that don't fit with tolerances sloppier than your mom’s whisker biscuit, little bit of gay stuff also.
I bet this guy has dicks on his dash.
Edit: auto correct got me again, I meant to type ducks
I can supply these :D
Shit, I wish I had 5.38s lol. And what is this shitty stock transfer case you speak of? I'm pretty sure the 231s have been known to hold almost 2k lb ft of torque, never mind the fact that I did a wheely in my jeep in because I had the t case in 4 low and dropped the clutch by accident.
chain drive junk. No front dig. Too long. Ratio isn’t low enough. 241s are overpriced junk also.
Anyone else love that this fucking guy paid for a new account after getting banned, just to talk low quality shit? Incredible.
Just changed my name. It was magically approved. Fits me better. I haven’t been banned. Why would I? Truth hurts? Not tolerant of the gays?
Wow. Its fits all years but 1. How hard is it to state that, it’s not like he didn’t know. It’s easy to check it if you know about the issue prior to ordering.
Because that isn't true. Some of the later years have the larger bar. Like I stated and you keep ignoring, this problem is a miniscule segment of the installs. I've done at least a 100 installs myself and only encountered it 1 1/2 times. The 1/2 is because I just put the new V bar in one that had the small bar otherwise I would have used some rubber fuel line and went on about my business. If I put that you need to check the bar diameter before ordering to see if you can use it, then I'll spend an inordinate amount of time dealing with scaring folks with a possible non fitment. Sadly, it is more desirable to deal with 1 asshole out of all the customer for one that didn't fit than deal with 100's worried about whether it will.
And again since it bears repetition, the other 4 just said, oh, I've got some hose, that will work, thanks.
Did he state it on his website? No? Why not?
Because it is far easier and less time consuming to deal with one sad little person than a 100 that need hand holding to figure out how to measure a V bar. Unless you've worked on both, it isn't immediately obvious they are different sizes. And, we still don't know exactly what and when the cut off is for the 2 sizes.
Dealing with the rotor hat difference that split in 99, I well know how this goes.
Because most people aren't miserable asshats when he provides a reasonable suggestion that's been deployed on whatever small number of these exist, without any known failures.
Just so we all stay on the same page, he was trying to make a trip and doing the install for that, at no point in time were the parts not going to be installed which made the refund upon his return home and used parts sent back more than a bit complicated.
BS. Parts weren’t used when I called. I said they didn’t fit the tube, you didn’t care, I didn't like your hack fix and moved on and made my own mount for the cooler. I never asked to return them after the trip. You’re making shit up. Our conversation was short and simple, Ill never make another purchase from you because of it.
