C Chach75 New Member Original poster Joined Feb 18, 2024 Messages 2 Location alabama Feb 18, 2024 #1 Does anyone have any suggestions for a replacement or part number for the boot or seal that goes on the steering column at the fire wall?
chili_pepper Acceleratti Incredibilis Supporting Member Joined Apr 27, 2023 Messages 6,235 Location Murrland Feb 18, 2024 #2 Chach75 said: Does anyone have any suggestions for a replacement or part number for the boot or seal that goes on the steering column at the fire wall? Click to expand... If you check out the resource section of this site, you'll find FSM's and parts lists for every year of TJ. You can view them online or download. Try this....https://wranglertjforum.com/attachments/1997-1999-tj-parts-list-pdf.14032/ and look for Figure 019-210 You may find some parts are discontinued by Chrysler and, in some cases, aren't available aftermarket. In those cases, Ebay and salvage yards are your friend. This will likely only get worse the older our TJ's get. Reactions: Jerry Bransford
macleanflood I break sh!t Supporting Member Ride of the Month Winner Joined Jul 24, 2021 Messages 11,868 Location Fall Creek, OR Feb 18, 2024 #3 And if it's just squeaking and squealing it just needs lube. Their is even a TSB about it. -Mac PS I wonder if cutting off a shock boot end would approximate that seal?
C Chach75 New Member Original poster Joined Feb 18, 2024 Messages 2 Location alabama Feb 18, 2024 #4 Thanks i will check that out
