2006 rubicon auto on 3.5 rubicon express w/33s tire pressure 28# Stock pitman arm, pretty sure toe and castor are OK I carefully set them and the Jeep felt good then and nothing seems to be loose or to have slipped in that area. I can let go of the wheel on the freeway hands off the wheel and everything tracks straight then will suddenly drift right (May also go left) also the steering has degraded where I have to stay on top and active or I’m back and forth in my lane (our calif roads suck too) steering play feels excessive to me. New symptom I can feel and hear a click at the end of the steering play from the wheel in both directions (2”Side to side) at the wheel and all over the steering linkage inspecting under the Jeep while my son cycled the steering although nothing moves out of place or looks loose and I’m not certain the play actually results in a true 2” play at the tires. I’ve also noticed a slight hot oil smell so I was thinking power steering box, but was also getting some intermittent vibration that feels like universal joint binding that could really be road related vibration from a bad rear shock absorber except I’ve noticed on occasion a slight rubbing noise when the Jeep is cold that sounds a bit like a dry wheel bearing this lasts just within the first min of driving? I found a rebuilt oem steering box for $400 after the core refund but am holding off pulling the trigger until I’m sure mine is bad? Any ideas suggestions and things I should look at? Could be a couple of things at the same time?
