Im looking to up bread steering on my 04 Rubicon many options out there what are opinions out there
I see you are a Currie man nothing wrong with that. I've been looking at the Currie currectlync. It seemed I have lots to learn on Lifts steering bumpstops and such. When reading the info on the Currie it states a 2 inch min bump stop (over stock) can you roughly explain thatYou'll want to read this thread in that case:
What is the best steering for my Jeep Wrangler TJ?
The sum that up though, there is no better steering setup (for stock axles at least) for your TJ than the Currie Currectlync steering.
Thank you for explaining that. I opted for a cheap lift and thil I'm paying for that in the long run. Lots to learnThe 2" minimum bump stop only applies to lifts under 4". This is due to the fact that at under 2" of lift, the Currie steering is beefy enough that under full compression / flex of the axles (without any bump stop), it will contact your front differential cover and potentially do damage. At 4" of lift this isn't as much of a concern (if any at all). However, bump stop should always be adjusted and added to any lifted TJ, regardless of whether or not it has aftermarket steering.
Currie is the only one out there (aside from doing the ZJ Tie Rod Conversion) that uses the factory style Haltenberger steering setup. Most people think they know better and decide to cheap out and go with a crossover type steering setup (which requires reaming the knuckles). Those steering setups end up almost always causing issues, and IMHO should always be avoided unless you have a very specific use case such as full width axles, massive amounts of suspension lift (i.e. 8"), or something very out of the ordinary.
Those crossover steering setups are absolutely pointless. They require way more work to install (as oppose to the Currie which just bolts-on), aren'y any stronger than a Currie setup, and often times problems arise such as death wobble, alignment issues, etc.
What steering upgrade should I get if I do not have a lift. I do however plan on putting in a 2 inch spacer kitYou'll want to read this thread in that case:
ZJ steeringWhat steering upgrade should I get if I do not have a lift. I do however plan on putting in a 2 inch spacer kit
Factory is fine or the ZJ tie rod.What steering upgrade should I get if I do not have a lift. I do however plan on putting in a 2 inch spacer kit
NoI don’t go off road but would like tighter steering is this going to help that?
What will help is rebuilding your steering components such as steering box, tie rod ends, etc.I don’t go off road but would like tighter steering is this going to help that?
I would recommend starting a new thread with some pictures of your front end and maybe some rough mileage estimates on those components, as well. From there, we could probably recommend a few things to try out.What upgrades can I make to tighten up steering?
Thank youWhat will help is rebuilding your steering components such as steering box, tie rod ends, etc.
Thank youI would recommend starting a new thread with some pictures of your front end and maybe some rough mileage estimates on those components, as well. From there, we could probably recommend a few things to try out.
made a new threadI would recommend starting a new thread with some pictures of your front end and maybe some rough mileage estimates on those components, as well. From there, we could probably recommend a few things to try out.
