I have a Kenwood HU. It has a 13 band equalizer and crossover settings. I'm running Polk DB525's front/rear and a sub in the center console powered by a small mono block amp. the amp has a LPF frequency setting and a gain setting. My question is, do I use the amp LPF frequency setting to set the sub, or do I open up the setting to let all frequencies thru and adjust them thru the HU crossover? The way I have it now I have the amp LPF frequency set around 70db. and the HU crossover set to "through" which allows all frequencies thru. The amp is under the dash, so making adjustment changes is not easy, so that is why I'm considering using the deck for adjustments.
