As for the crossover frequency, 120 Hz is probably a good target for your system. The smaller subs can reproduce higher bass frequencies better than the smaller speaker woofers. If you find the bass seems harsh at higher frequencies compared to lower frequencies then you can play with the cutoff slope to try and attenuate the higher bass frequencies. Alternatively you can use the 13 band EQ to do the same.
