1. Want to have your TJ featured as the September 2018 "Ride of the Month"? The winner will receive a $200 gift card from Metalcloak! Click here to submit a photo of your TJ. Submissions are accepted until August 20th!
    Dismiss Notice
Stock Sway Bar Question...
Discussion in 'TJ General Discussion' started by EJD, Mar 12, 2018.
  1. EJD
    EJD TJ Overlander
    Supporting Member Ride of the Month Winner
    Thread Starter
    Jul 16, 2016
    1,260
    1,114
    Missoula, MT, USA
    I was working on installing my new front bumper today and I was trying to line up the bumpers mounting holes with the ones on the frame and since i'm installing a winch and have a touch of OCD I just wanted to to be as centered as possible.
    I took measurements from the furthest edge of the sway bar on each side to each end of my bumper and long story short, turns out my sway bar is not completely centered. It is a half inch over center on the passenger side, meaning the driver side is a half inch under center.
    It just got me thinking is this supposed to be dead centered? or is this being out of "alignment" potentially causing and different body roll on one side? or anything at all? Just curious as I have no idea and would like to understand things better.
    Thanks in advance!
  2. glwood
    glwood TJ Expert
    Sep 16, 2016
    4,264
    3,692
    Albuquerque, NM
    I don't believe it really matters, as long as none of the link ends are hitting anything. It's going to want to move some horizontally due to it not having any actual retainer as such.
    EJD and StG58 like this.
  3. EJD
    EJD TJ Overlander
    Thread Starter
    Jul 16, 2016
    1,260
    1,114
    Missoula, MT, USA
    Yeah I just wasn't sure if it made any ride difference. End links are a few inches away from anything, so looks like no big deal. Thanks!
  4. jjvw
    jjvw 0-60 in 18 seconds
    Feb 17, 2018
    1,536
    1,395
    Colorado, USA
    The stock front sway bar tends to wander from side to side a bit.
    2003 Rubicon
  5. Jerry Bransford
    Jerry Bransford TJ Guru
    Nov 9, 2015
    6,753
    7,469
    Escondido California
    The antiswaybar has some available side-to-side movement to follow the axle as it moves side-to-side as it moves up & down. The track bar makes the axle move sideways as the front suspension moves up & down.
    EJD likes this.
  6. TJ4Jim
    TJ4Jim TJ Enthusiast
    Dec 9, 2015
    998
    691
    Brookings, Oregon
    As others have stated the sway bar does have movement but if the bushings are toast that's a different issue.
Share This Page
