Hey guys I have 2005 TJ wrangler that has been accumulating water on the drivers side floor. I removed the cowl and had my wife watch for the leak while spraying with a hose, and we found the source. I am beyond baffled on how I can fix it though. In the picture I am pointing at the source. There is a side drain on both sides of the cowl that drain down the side of the Jeep and out the bottom. It is flowing out of the bottom well but somwhere inside that mystery region of the tub it is leaking in. I can’t visualize the exact leak because it is above the flat part of the bracket assembly that the clutch and brake pedals attach to. Would it be stupid to completely seal up that cowl drain? If can’t access the exact leak from inside or outside, what the hell else am I supposed to do? It is like the Jeep is trying to commit suicide by rust !
