Drove the thing a ton last weekend — Dallas to Tulsa, then Tulsa to Springfield MO, wheeled 2 days, then Springfield all the way back to Dallas. So basically 14 hours of travel & another 15 hrs of trail time. Then about 45 minutes from home, a strange thing happened.
1. started squealing, which is almost certainly the belt.
2. Voltmeter on the gauge cluster went to 0V. Well, ok, it doesn't really read anything below 9, it was effectively "off."
3. The auxiliary voltmeter I have powered off the cigarette lighter showed 11ish volts, which is as low as I've ever seen it read.
4. Temp gauge started rising. The entire trip it never budged off the 210 mark, but it was now halfway between the 210 mark and the 3/4 mark. It reached some maximum around that point, possibly aided by the fact that it was in the low 50s outside and I was doing 60+
5. all other Jeep function, gauges, lights, etc appeared to be unaffected.
While this was happening, "something else" happened; I heard a pop in my speakers, my stereo rebooted and for a moment the dash voltmeter read 14 again, but it didn't last long before it dropped to 0 again.
I pulled over & popped the hood, and it definitely seemed like the squealing was coming from the area around the alternator, but everything was spinning w/o any obvious slippage. I had power steering the entire time as well. While I was stopped I kept looking at the temp gauge and it never got any higher, but it also wasn't going back down to 210.
So I turned off all my accessories (headlights [it was 2pm but overcast], radio, & heater blower) and got back on the road. A short while later the squealing stopped, the dash voltmeter showed 14V for a short while, but then went back to "0V". The engine temp went right back down to 210. Meanwhile the aux voltmeter was erratically bouncing between 13.8 and 14.4. Since I installed that voltmeter (really it's just a dual USB that happened to also have a voltmeter), it typically reads right at 13.8V while driving. Prior to this the dash gauge would always read just over 14V.
I put a Gates belt on about a year ago so I'd be surprised if it was already bad but obviously I can't rule it out. But then the squealing stopped and didn't return for the last hour of the trip. When I got it in my driveway I turned it off, and then restarted it...It started right back up and the gauge cluster read 14V again. Let it sit for 2 days and then moved it, again no issue starting and the voltmeter read 14V.
Obviously I'm at a loss for what happened, but I'm also confused as to why the 2 voltmeters would read differently. I haven't had a chance to look through the diagram yet to see how that voltmeter gets its signal; does it actually measure the voltage drop or does it get "instructions" from the PCM on what to display?
Would love to hear some ideas.
