I enjoy checking in on your build. You take a different path, which is nice to see!![]()
A couple weeks ago, I dropped the rig on all 4. Threw a tool bag in the back and told my wife I needed her 120 lbs. to also sit in the back. I don't plan on running a spare, at the moment. With some 16", 250 # coils, I adjusted the dual rate sliders to set the rig at desired ride height. Took shaft & coil spring measurements then called up Poly Performance. Additionally, I wanted the coilovers tuned. I could have gone with Accutune but here on the East Coast, we're an eclectic group. After speaking with several seasoned offroad veterans, I decided to send them to Chris Weygandt @ Diddy's Big Block Race Shop. His service was very professional, always took your call and did a few extra things (besides valving). We shall see how they perform. However, hopefully I got the rate & coil spring selection right on the first try.. If not, gotta thank Poly for coil spring swap exchange.
While waiting for an alignment (scheduled 9/14), I took care of a few odds & ends.
1. Found out I cross-wired the front locker & sensor. Fixed the wiring and now both axle lockers & sensors function properly.
2. Made new front lower fender liners.
3. Applied eastwood internal frame coating.
IT's looking good & I'd imagine it's got to feel GREAT to be driving it.
Well, gremlins are starting to surface. Always typical with a new build. The Jeep went to an offroad shop specializing in 4-wheel alignment. Ocean State Offroad did a great job dialing it in. It's been driving fine for the 30 minutes since completed and test drive was fine. However, just prior to loading it onto the trailer, steering input would not turn passenger! Disconnected the cylinder from the tie-rod and it functioned fine without. Cylinder would not extend, only retract.
I got it onto the trailer and removed the cylinder from the axle when I returned home. I could not turn the rod end by hand. Assuming the shaft was bent, I attempted to remove the gland nut with a pin wrench. However no lukc, and it took a 36" pipe wrench to remove. Yes, I marred up the collar of the gland nut but I'll file it and keep an eye on it. Like a kid on prom night, the shaft was very difficult to pull out. PSC steering made this delrin spacer to limit the stroke to 6" but it's a very tight tolerance to the ID of the cylinder and I suspect, when fully extended, it blocks one of the ports. Or, Delrin swells in oil & heat? either way, I'll turn it down some but hopefully this is the root cause.
@mrblaine ?
...In terms of a forward stretch, I netted 2.5"...
Steering box is in the factory location. I'm follwing a build on the FB page "Jeeps with JK/JL axles" and there's someone who claims he got 4" of forward stretch. I can't see how the hell he did (unless he exaggerates).
Looks like a shorter pitman arm and the track bar is lower than the drag link, in parallel.Lots of ways to do it, they will compromise a lot of things in return but it isn't that hard. The main problem is how close you can move the trackbar to the draglink. If you run a short pitman, you can move the trackbar forward and get it out of the way of the axle moving up. Or, don't let the axle move up as high.
The short pitman is going to suck getting the knuckles lock to lock but you can move the axle forward from stock 4".
However, I'm going to go with most of his stretch being the truth. Unless he moved the stock coil spring buckets, a side shot would show what's going on.
