If you're talking about your 32rh,3.07's and 31s specifically then yes you'd be happy with a stroker. Its no v8,but it is what the 4.0l should have been. People use much higher gears with the 32rh than all other tj transmissions.
As to power band comparisons it would be rediculous to run a stroker at the same rpms as a 4.0l assuming you don't have a huge cam.
The jeep only needs so much power to go down the highway. I'm not lugging my stroker at 1800rpms and 1/8 throttle. All it does sitting at 2500 rpms is use more fuel
Back of the envelope calculation:
4.7/4.0 = 1.175.
3.07 * 1.175 = 3.60.
assuming a proportional increase in torque going from the 4.0 to the stroker, I'd expect a 4.7 with 3.07's to perform as well as a 4.0 with 3.60 gears. I think most guys would be pretty happy with a 4.0 and 3.60 gears and 31" tires under any conditions.
