Go ahead and use a propane torch on the perimeter, they must have used red Loctite or something similar to install it, It'll take about 200 to 250 degrees to break it loose and that's not hot enough to set the gear oil on fire.
He won't need one. Rocks are tougher than hitting it with a hammer and the rig hits much harder than he can.LMK id you need a new cover. Stripping some axles and I will have an extra cover sitting here for the cost of shipping
Good luck with your removal!
LMK if you need a new cover. Stripping some axles and I will have an extra cover sitting here for the cost of shipping
Put a box end wrench on one of the ring gear bolts, turn the pinion with a pipe wrench or by sticking a prybar through the yoke, let the wrench hit the edge of the diff opening, that will crank the carrier right out.Now to get the loaded diff out of the housing which is proving to be yet another challenge!!!
Thank you so much for the offer but mrblaine was right on. After a good night's rest, a hearty breakfast, a handful of ibuprofen and following mrblaine's instructions — I tried to knock the diff cover into the passenger seat and on about blow number 25....success.
My bet would be Mopar Gear Oil specific RTV.So, what was on there that made it so tough to get off?
