I need to add ATF to top up my auto trans but ATF-4 is not available any where in New Zealand currently.
Is there a substitute?
Thanks Jerry Thought that might the caseNo, it really does need to be ATF+4. Sorry but you're going to need to order it.
You don't have access to Valvoline, Castrol, Redline etc.?I need to add ATF to top up my auto trans but ATF-4 is not available any where in New Zealand currently.
I'd top it off with Amsoil and change it out when it comes back in stock. I could have easily sent some though had I known you were in need. Still can if it comes to it.I need to add ATF to top up my auto trans but ATF-4 is not available any where in New Zealand currently.
Only need about a litre to top up. I’ll try again next week and see what I can find. Not sure if we have Amsoil hereI'd top it off with Amsoil and change it out when it comes back in stock. I could have easily sent some though had I known you were in need. Still can if it comes to it.
I did a search and there is a distributor in the same State/Province/WTFE we shipped the case to.Only need about a litre to top up. I’ll try again next week and see what I can find. Not sure if we have Amsoil here
https://www.amsoil.com/international/distributor/countries/newzealand.aspxCan you send me the link please
Jerry do you know what’s in the ATF-4 that makes it so vital for Jeep Auto trans?Thanks Jerry Thought that might the case
Thanks MrBlaine. They are closed until Monday so will follow up on it then. I assume that Amsoil is only for topping up until I can get the +4
That is how I would do it unless they have a very convincing argument that their special fluid will work in place of ATF+4. Convincing enough that they will pay for a trans if it doesn't work. The reason I would use Amsoil multi vehicle is due to it being full synthetic. ATF+4 is either full synthetic or nearly so.Tha
Great research thanks MrBlaine. I’ve been working on my market stall all day so not had time to do much rrasesrch of my own. Looks like you have saved me a lot of time. Just home now will start following up after I’ve had my diner. Won’t be able to talk to any one at Amsoil till Monday thoughIf you use the correct oil and their oil is at fault, they will pay to repair:
https://amsoilcontent.com/ams/lit/g1363.pdf
Their ATF is recommended as a replacement for ATF+4 in the 42RLE Jeep application: https://www.amsoil.com/p/signature-series-multi-vehicle-synthetic-automatic-transmission-fluid-atf/
So my understanding is that OP would be covered if Amsoil caused the failure.
I read an article about that many years ago and while the specifics are a bit fuzzy, it had to do with the front wheel drive mini van transmissions and the shifting issues they had. They developed a new fluid that wound up being either full synthetic or nearly so to solve those issues which also made the requirement that all companies who sell a version meet that spec. That requirement is also why I use a lot of Walmart brand ATF+4.Jerry do you know what’s in the ATF-4 that makes it so vital for Jeep Auto trans?
If my memory serves me correctly, it had something to do with a slip addative being added to the fluid. This was supposed to make the shifts less harsh on the FWD vehicles. At least thats what the corporate told us when I worked for Dodge.I read an article about that many years ago and while the specifics are a bit fuzzy, it had to do with the front wheel drive mini van transmissions and the shifting issues they had. They developed a new fluid that wound up being either full synthetic or nearly so to solve those issues which also made the requirement that all companies who sell a version meet that spec. That requirement is also why I use a lot of Walmart brand ATF+4.
